Introdução
Accessing the RAM is easy and requires only a Phillips screwdriver.
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
28 outras pessoas concluíram este guia.
