Introdução
This guide shows the hidden screws you must remove when replacing the keyboard.
O que você precisa
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
On the keyboard, remove the F1, F2, F11, and F12 keys.
This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
Whenever I’ve had to remove a key cover, I’ve used a chip extraction tool. It’s ‘u’ shaped with two tabs facing inwards. It will allow the tabs to fit under the lip of the key covers and a gentle motion will allow you to pull up.
Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
Carefully lift edges of foil tape across logic board connector end of keyboard cable (foil is present if unit
has not been apart before).
Grasp cable near the connector and gently pull straight up (perpendicular to logic board).
4 outras pessoas executaram este guia.
