Ir para o conteúdo principal
PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade
O que você precisa
  1. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade, Battery: passo 1, imagem 1 %32
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade, LCD: passo 2, imagem 1 %32
    • Open the computer and rotate the display as far as possible.
    • Remove the T6 Torx screw from the bottom left corner of the display assembly. The computer casing will not allow the screwdriver to be inserted directly into the screw, so be careful not to strip the screw.
  3. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the T6 Torx screw from the bottom right corner of the display assembly.
    • To avoid cross-threading these screws during reinstallation, use a pair of tweezers to start each screw in its hole before using your Torx screwdriver to tighten them.
  4. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 4, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 4, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 4, imagem 3 %32
    • The next steps involve the use of plastic opening tools and spudgers which will probably be ruined in the process. Have a few spares of each tool handy.
    • Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
    • Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
    • Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
    • Freeing these tabs may require some force. Be sure to support the display assembly with your other hand to avoid putting too much strain on the hinges.
  5. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 5, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 5, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 5, imagem 3 %32
    • Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  6. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 6, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 6, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 6, imagem 3 %32
    • Close the display.
    • The rear display bezel is still attached to the display via the antenna cables.
    • Lift the bottom edge of the rear display bezel up about an inch.
    • Slide the rear display bezel forward to release the clips along the top edge of the display.
    • Rotate the rear display bezel away from the display and lay it next to the computer.
  7. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 7, imagem 1 %32
    • Remove the Phillips screw securing the inverter board.
  8. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 8, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 8, imagem 2 %32
    • Insert the pointed end of the a spudger between the protective tape and the inverter board.
    • Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
    • Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
    • Gently remove the board in order to avoid damaging any wires or connectors.
  9. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 9, imagem 1 %32
    • Disconnect the cable by pulling the connector away from the inverter board's socket.
  10. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 10, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 10, imagem 2 %32
    • Remove the two Phillips screws from both sides of the display (four in total).
  11. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 11, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 11, imagem 2 %32
    • Remove any tape on the display data cable.
    • Pull the display data cable connector away from its socket to disconnect it from the LCD.
  12. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 12, imagem 1 %32
    • Open the display slightly.
    • Push the LCD away from the front display bezel near its top edge.
    • Remove the LCD, being wary of any cables that may get caught
  13. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade, LCD panel upgrade: passo 13, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade, LCD panel upgrade: passo 13, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade, LCD panel upgrade: passo 13, imagem 3 %32
    • Some HV121P01 are IBM/Lenovo/Thinkpad parts. Comes with Wacom Digitizer and front shield. Remove the Wacom Digitizer first.
    • 1. remove the 4 philips screws in red circles.
    • 2. use some thin object, like a knife, to separate the 2 double sided tapes in red rectangles from the white plastic back.
    • The front shield can protect the screen during the following steps, remove it only after anything else are done!
  14. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 14, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 14, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 14, imagem 3 %32
    • Lift 2 ends of tape,at the CCFL side, and remove 2 black philips screws in the red circles.
    • Remove the 2 small metal parts in the red rectangles.
  15. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 15, imagem 1 %32
    • You need to extend the CCFL High Voltage cable, if it is not long enough to reach the inverter. You'd better get a electronics friend to help you. Should be very easy for him. If it's done wrong. Leakage or shock may happen.
    • Please measure and calculate the cable length precisely. There is not enough space for wires which are too long. In this pic, they ARE 25mm/1" longer than needed. Reworking them is painful.
  16. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 16, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 16, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 16, imagem 3 %32
    • Remove all the extra parts from the PCB, metal frame, and white plastic back. There are 9 of them. Use knife or other cutting tool to cut the plastic. Use cutting tool to cut PCB. Use Diamond impregnated files to cut the metal frame. It's very hard and stiff, you cannot cut it with knife or wire cutters. Or, you may hurt you tool or even the LCD GLASS!! That's a game over"
    • Please be ALWAYS VERY CAREFUL and patient, DO NOT HURT the citcuit or the LCD glass (through the entire upgrade).
    • Smooth all sharp metal edges. Should be 6 of them.
    • After this step, your HV121P01 will look more like the original LCD panel i.e. IAXG01B
  17. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 17, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 17, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 17, imagem 3 %32
    • More pics for last step.
  18. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 18, imagem 1 %32
    • One more pic for last step.
  19. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 19, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 19, imagem 2 %32
    • Drill four 1.5mm~2mm(1/16"~5/64") diameter, 3mm(1/8") deep holes at the left and right side of panel at the position corresponding to original LCD panel. Do NOT drill the glass!!.
    • 2 will be drilled on metal and then plastic, 2 on plastic. As said before, the metal is very hard! use high quality drill and be patient and avoid overheating, or you'll burn your hand or the plastic and LCD glass.
    • In these pics, the upper LCD is the original one, the bottom one is HV121P01.
  20. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 20, imagem 1 %32
    • Remove the front shield, if any. It's positioned by double sided tape. Should not be very tight. But, still, be very careful about the LCD glass. if you have to break some thing, it should be the shield or tape.
    • remove any tape, glue.
  21. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 21, imagem 1 %32
    • Apply some electric tape here, to avoid short circuit.
  22. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 22, imagem 1 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 22, imagem 2 %32 PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 22, imagem 3 %32
    • Connect the Cables.
    • The LVDS cable connector position is different. So the cable will not be flat enough. cut the transparent tape around the wires. Reposition the cable, and then using tape to hold them in position.
    • Hold the PCB with tape.
  23. PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade: passo 23, imagem 1 %32
    • screw in 4 screws (not photoed, check LCD guide).
    • check the cable connections again. Assemble the inverter screw.
    • Power on and test. It's 1400x1050 now.
    • This might be the world's highest resolution 12" PowerBook.
Conclusão
7 outras pessoas executaram este guia.
Terrance
Membro desde: 11/17/09
6.368 Reputação
Autoria de 17 guias
5 comentários
Fantastic .... great job ... I was considering getting my PB G4 12' upgraded this way, but I could not find anyone to do it.
Can You please comment on the battery/energy consumption after the upgrade ... or any quirks etc?
Thank You.
P.B. - Responder
This was a great guide!
Truls Clausen Waage - Responder
Would something like this be compatible with a 12” iBook G4?
lilliputian - Responder
Tear it down and see what’s inside.
Terrance -
Hey @terrance3774, I really want to drop this panel into my 12” G4 but don’t feel like taking this task on. Do you have one already made up that I could purchase from you? Thx!
Stephen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 52
Duração total: 14,798
