Introdução
Replacing this keyboard is easy and takes only a few minutes.
Ferramentas
Nenhuma ferramenta especificada.
Peças
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
8 outras pessoas concluíram este guia.
