Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
Rest the keyboard on the trackpad.
1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
2) After disengaging the locking bar, slide the cable out of the connector.
Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
Once the strain relief cables are free, lift the keyboard off.
Remove the two Phillips screws from the heat shield.
Grasp the metal handle on the heat shield and pull up and toward yourself.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
Grasp the hard drive bracket on the left side and pull up and to the left.
Remove the four T8 Torx screws from the hard drive bracket.
Turn the hard drive bracket over.
Hold the hard drive bracket at the connector end and grasp the opposite end of the hard drive.
Pull the hard drive out of the bracket, making sure to pull evenly on both sides.
40 outras pessoas executaram este guia.
Documentos anexados
2 comentários
You absolutely do not need to remove the keyboard ribbon cables in order to replace the hard drive. You just need to be careful and the HDD caddy will come out just fine. As someone who has had some bad experiences with ribbon cables, I prefer not to remove them unless absolutely necessary.
