Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
How to remove the hard drive and its bracket from your computer.
O que você precisa
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
9 outras pessoas executaram este guia.
