Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
Lift the heat shield up and pull it toward you.
Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
Disconnect the antenna cable from the Airport card.
Pull the battery cable directly up from the logic board.
Remove the battery from its holder by pulling up and to the left.
Remove the long silver Phillips #1 screw from the heat sink.
Remove the two T8 Torx screws that attach the heat sink to the processor.
Lift the heat sink up from the left side and pull it out.
Grasp the plastic tab on the processor's right side and pull it directly up.
Remove the black Torx screw from the right side of the modem.
Remove the small black plastic rectangle with four holes.
Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
Disconnect the cable from the right side of the modem.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
Push the display back so that it lies flat.
Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
Repeat the previous step on the left side.
Lift the clutch cover up and off, rotating it toward yourself.
