Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
Lift the heat shield up and pull it toward you.
Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
Disconnect the antenna cable from the Airport card.
18 outras pessoas executaram este guia.
