Ir para o conteúdo principal
PowerBook G3 Lombard Processor Replacement
O que você precisa
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Processor Replacement: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Processor Replacement: passo 3, imagem 1 %32
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Processor Replacement: passo 5, imagem 1 %32
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Processor Replacement: passo 6, imagem 1 %32
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: passo 7, imagem 1 %32
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Processor Replacement: passo 8, imagem 1 %32
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Processor Replacement, Modem: passo 9, imagem 1 %32
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Processor Replacement: passo 10, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Processor Replacement: passo 11, imagem 1 %32
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Processor Replacement: passo 12, imagem 1 %32
  13. PowerBook G3 Lombard Processor Replacement, Processor: passo 13, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard Processor Replacement: passo 14, imagem 1 %32
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard Processor Replacement: passo 15, imagem 1 %32
Conclusão
5 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 5,870
