Ir para o conteúdo principal
PowerBook G3 Lombard PRAM Battery Replacement
O que você precisa
  1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard PRAM Battery Replacement: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard PRAM Battery Replacement: passo 3, imagem 1 %32
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: passo 4, imagem 1 %32
    • Pull the battery cable directly up from the logic board.
  5. PowerBook G3 Lombard PRAM Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from its holder by pulling up and to the left.
Conclusão
5 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
2 comentários
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - Responder
Seems the step I was referring to are no longer there!
Godzil -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 30
Duração total: 10,943
