Introdução
How to remove the PCMCIA card cage holder.
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the RAM chip out.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
Grasp the orange display data cable and disconnect it from the logic board.
Pull the display cable straight up so that it is vertical.
Turn the laptop around so that its back faces you.
Open the port door located at the back of the laptop.
Remove the four black Torx screws.
Remove the three long silver and two short black Torx screws from the beige plastic casing.
Remove the two long silver Torx screws from the power card in the center of the laptop.
Grasp the power card near the black plastic shield and lift up.
Remove the single short black Torx screw anchoring the metal framework to the lower casing.
Use a five millimeter nut driver or needle-nose pliers to remove the small metal nut from the bolt in the laptop's back left corner.
Turn the laptop around so that the front faces you.
Move the metal yoke to the left, making sure to leave the spring attached.
Turn the logic board over.
Remove the four Phillips screws holding the PC card cage to the logic board.
Uma outra pessoa concluiu este guia.
