Ir para o conteúdo principal
PowerBook G3 Lombard Hard Drive Replacement
O que você precisa
  1. PowerBook G3 Lombard Hard Drive Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Hard Drive Replacement: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Hard Drive Replacement: passo 3, imagem 1 %32
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Hard Drive Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Hard Drive Replacement: passo 5, imagem 1 %32
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Hard Drive Replacement: passo 6, imagem 1 %32
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Hard Drive Replacement, Modem: passo 7, imagem 1 %32
    • Remove the two silver Phillips screws from the modem.
  8. PowerBook G3 Lombard Hard Drive Replacement: passo 8, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  9. PowerBook G3 Lombard Hard Drive Replacement: passo 9, imagem 1 %32
    • Disconnect the cable from the right side of the modem.
  10. PowerBook G3 Lombard Hard Drive Replacement: passo 10, imagem 1 %32
  11. PowerBook G3 Lombard Hard Drive Replacement, Processor: passo 11, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  12. PowerBook G3 Lombard Hard Drive Replacement: passo 12, imagem 1 %32
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  13. PowerBook G3 Lombard Hard Drive Replacement: passo 13, imagem 1 %32
  14. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: passo 14, imagem 1 %32
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  15. PowerBook G3 Lombard Hard Drive Replacement: passo 15, imagem 1 %32
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  16. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: passo 16, imagem 1 %32
    • Remove the four black Torx screws located at the four corners of the hard drive bracket.
  17. PowerBook G3 Lombard Hard Drive Replacement: passo 17, imagem 1 %32
    • Pull the connector cable out from the hard drive, applying even pressure while gently rocking up and down.
    • Be very careful to apply even pressure when removing the cable. If you torque too hard to either side, you may damage or destroy the hard drive's connector pins, rendering your data inaccessible.
Conclusão
10 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 41
Duração total: 12,024
