Introdução
Change out the entire display assembly, including the hinges and plastic casing.
O que você precisa
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the RAM chip out.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
Grasp the orange display data cable and disconnect it from the logic board.
Pull the display cable straight up so that it is vertical.
Turn the laptop around so that its back faces you.
Open the port door located at the back of the laptop.
Remove the four black Torx screws.
4 outras pessoas executaram este guia.
