Ir para o conteúdo principal
PowerBook G3 Lombard Display Replacement
O que você precisa
  1. PowerBook G3 Lombard Display Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G3 Lombard Display Replacement: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G3 Lombard Display Replacement: passo 3, imagem 1 %32
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G3 Lombard Display Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G3 Lombard Display Replacement: passo 5, imagem 1 %32
    • Lift the heat shield up and pull it toward you.
    Pergunte ao FixBot
    Comentar
  6. PowerBook G3 Lombard Display Replacement: passo 6, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  7. PowerBook G3 Lombard Display Replacement, PRAM Battery: passo 7, imagem 1 %32
    • Pull the battery cable directly up from the logic board.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G3 Lombard Display Replacement: passo 8, imagem 1 %32
    • Remove the battery from its holder by pulling up and to the left.
    Pergunte ao FixBot
    Comentar
  9. PowerBook G3 Lombard Display Replacement, Modem: passo 9, imagem 1 %32
    • Remove the two silver Phillips screws from the modem.
    Pergunte ao FixBot
    Comentar
  10. PowerBook G3 Lombard Display Replacement: passo 10, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    Pergunte ao FixBot
    Comentar
  11. PowerBook G3 Lombard Display Replacement: passo 11, imagem 1 %32
    • Disconnect the cable from the right side of the modem.
    Pergunte ao FixBot
    Comentar
  12. PowerBook G3 Lombard Display Replacement: passo 12, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  13. PowerBook G3 Lombard Display Replacement, Processor: passo 13, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    Pergunte ao FixBot
    Comentar
  14. PowerBook G3 Lombard Display Replacement: passo 14, imagem 1 %32
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
    Pergunte ao FixBot
    Comentar
  15. PowerBook G3 Lombard Display Replacement: passo 15, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  16. PowerBook G3 Lombard Display Replacement, RAM: passo 16, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
    Pergunte ao FixBot
    Comentar
  17. PowerBook G3 Lombard Display Replacement, Hard Drive: passo 17, imagem 1 %32
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Pergunte ao FixBot
    Comentar
  18. PowerBook G3 Lombard Display Replacement: passo 18, imagem 1 %32
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Pergunte ao FixBot
    Comentar
  19. PowerBook G3 Lombard Display Replacement, Clutch Cover: passo 19, imagem 1 %32
    • Push the display back so that it lies flat.
    Pergunte ao FixBot
    Comentar
  20. PowerBook G3 Lombard Display Replacement: passo 20, imagem 1 %32
    • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    Pergunte ao FixBot
    Comentar
  21. PowerBook G3 Lombard Display Replacement: passo 21, imagem 1 %32
    • Lift the clutch cover up and off, rotating it toward yourself.
    Pergunte ao FixBot
    Comentar
  22. PowerBook G3 Lombard Display Replacement, Inverter: passo 22, imagem 1 %32
    • Grasp the orange display data cable and disconnect it from the logic board.
    • Pull the display cable straight up so that it is vertical.
    Pergunte ao FixBot
    Comentar
  23. PowerBook G3 Lombard Display Replacement: passo 23, imagem 1 %32
    • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
    • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
    Pergunte ao FixBot
    Comentar
  24. PowerBook G3 Lombard Display Replacement: passo 24, imagem 1 %32
    • Disconnect the white inverter cable connector from the right end of the board.
    Pergunte ao FixBot
    Comentar
  25. PowerBook G3 Lombard Display Replacement: passo 25, imagem 1 %32
    • Disconnect the inverter plug, pulling directly up from the logic board.
    Pergunte ao FixBot
    Comentar
  26. PowerBook G3 Lombard Display Replacement: passo 26, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  27. PowerBook G3 Lombard Display Replacement, Display: passo 27, imagem 1 %32
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
    Pergunte ao FixBot
    Comentar
  28. PowerBook G3 Lombard Display Replacement: passo 28, imagem 1 %32
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
    Pergunte ao FixBot
    Comentar
  29. PowerBook G3 Lombard Display Replacement: passo 29, imagem 1 %32
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 80
Ao todo: 8,930
