Introdução
Removal of the track pad panel is necessary to reach the hard drive and track pad.
O que você precisa
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Push the display screen back to give yourself enough space to remove the side panels.
Remove the panels on either side by gently but firmly pulling up on them with both hands.
Uma outra pessoa concluiu este guia.
