Introdução
In order to access the display or replace any portion of the sound system you must first remove the speaker panel from the computer.
O que você precisa
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Uma outra pessoa concluiu este guia.
