Ir para o conteúdo principal
PowerBook 180 Ram Replacement
O que você precisa
  1. PowerBook 180 Ram Replacement, Ram: passo 1, imagem 1 %32 PowerBook 180 Ram Replacement, Ram: passo 1, imagem 2 %32
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. PowerBook 180 Ram Replacement: passo 2, imagem 1 %32 PowerBook 180 Ram Replacement: passo 2, imagem 2 %32
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. PowerBook 180 Ram Replacement: passo 3, imagem 1 %32 PowerBook 180 Ram Replacement: passo 3, imagem 2 %32
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  4. PowerBook 180 Ram Replacement: passo 4, imagem 1 %32
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  5. PowerBook 180 Ram Replacement: passo 5, imagem 1 %32 PowerBook 180 Ram Replacement: passo 5, imagem 2 %32
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
Conclusão
3 outras pessoas executaram este guia.
Jack Byrnes
Membro desde: 10/17/10
1.244 Reputação
Autoria de 2 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 3,176
