Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Peças
Nenhum componente especificado.
  1. Remove the Ni-Cad battery from the PowerBook 180. Slide the arrows toward the front of the computer until the battery can slide out.
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. Removing the screws securing the bottom plate from the PowerBook 180. There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  4. Your computer should look like the two pictures after the bottom plate is removed. Your computer should look like the two pictures after the bottom plate is removed.
    • Your computer should look like the two pictures after the bottom plate is removed.
  5. Locate the modem board, which is next to the DC-in port. There are two Torx T8 screws marked in red in the pictures.  Remove these screws and pull up on the modem board to remove.
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
Conclusão
3 outras pessoas concluíram este guia.
Jack Byrnes
Membro desde: 17/10/2010
1.223 Reputação
2 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
294 Membros
942 Guias de autoria
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,116
