Ir para o conteúdo principal
PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
O que você precisa
  1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery.: passo 1, imagem 1 %32
    • The battery is located inside the right side ear piece.
  2. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Heat Right Side.: passo 2, imagem 1 %32
    • Heat the right side gently at 140 F for about 3 minutes.
    • Do not over heat or it will melt the housing.
  3. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: passo 3, imagem 1 %32 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: passo 3, imagem 2 %32
    • After heating, gently remove the cover/casing as shown in the picture.
    • Take your time and re-heat if cover/casing does not remove smoothly.
  4. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Desolder & Replace Battery: passo 4, imagem 1 %32
    • Desolder battery using soldering iron and replace with replacement battery.
  5. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: passo 5, imagem 1 %32 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: passo 5, imagem 2 %32
    • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
    • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
Conclusão
9 outras pessoas executaram este guia.
Faizan Naveed
Membro desde: 04/12/17
3.294 Reputação
Autoria de 8 guias
Equipe
Mobile Device Repair Factory Membro de Mobile Device Repair Factory
Business
1 Membro
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 48
Duração total: 26,834
