Ir para o conteúdo principal
PowerA Spectra Infinity Enhanced Vibration Motors Replacement
O que você precisa
  1. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: passo 1, imagem 2 %32
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 2, imagem 1 %32
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 3, imagem 1 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 3, imagem 2 %32
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 4, imagem 1 %32
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 5, imagem 1 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 5, imagem 2 %32
    • Use your hand to separate the motherboard from the face plate.
  6. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: passo 6, imagem 1 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: passo 6, imagem 2 %32
    • Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
  7. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 7, imagem 1 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 7, imagem 2 %32
    • Use tweezers to unplug the small plug connecting the motors to the motherboard.
    • A firm grip may be necessary for this step.
  8. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 8, imagem 1 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 8, imagem 2 %32 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 8, imagem 3 %32
    • Remove the completely freed vibration motor from the motherboard.
Conclusão
Kevyn Jorge
Membro desde: 03/22/24
1.012 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 341
