Ir para o conteúdo principal
PowerA Enhanced Wireless Controller L and R buttons Replacement
O que você precisa
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, imagem 3 %32
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
Conclusão
Uma outra pessoa concluiu este guia.
Ayjah Montgomery
Membro desde: 10/10/19
402 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
Membros da 3
Autoria de 10 guias
2 comentários
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - Responder
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 49
Duração total: 3,127
