Ir para o conteúdo principal
PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement
O que você precisa
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: passo 5, imagem 1 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: passo 5, imagem 2 %32 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: passo 5, imagem 3 %32
    • Pull the L and R stick covers out of the socket.
Conclusão
13 outras pessoas executaram este guia.
Ayjah Montgomery
Membro desde: 10/10/19
420 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
21Comentários do guia
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - Responder
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - Responder
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl -
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 48
Últimos 30 dias: 208
Ao todo: 16,110
