Introdução
This guide will show you how to access and replace the L and R thumbsticks of your PowerA Enhanced Wireless Controller. If your buttons are sticking or result in drift, this is why you might need to replace or clean your thumbsticks.
Before starting, make sure to clean the controller of debris so the replacement is easier. Usually, thumbsticks can become worn out over multiple times of use, so replacing them can help with better gameplay. The pieces of this replacement can be fairly small, so having a steady hand and organization will be useful. This repair may seem unneeded because you can buy a new controller instead. Just doing this replacement can save you money and time. New parts may be required for this so make sure to buy your correct replacement parts in advance on either the Xbox website or your local gaming store.
O que você precisa
Remove the battery cover by pressing down on the lever located on the top of the cover.
Apply pressure until it clicks out of place, and pull it off.
Pull the L and R sticks out of the socket.
I am having a hard time sourcing the parts for this repair. Any tips on where to order new L and R sticks, or analog thumbsticks, as I’m seeing them referred to? I ordered Nintendo Pro Controller analog thumbsticks online and could not complete the repair as the underside of the knobs were not the right shape/fit. I need PowerA Enhanced Wireless Controller parts. Help!
I’m having the same issue. Regular replacement joystick won’t fit and I can’t seem to find joysticks for specifically power A wireless controllers. Have you had an luck since commenting this?
Anyone have any luck? Also looking for the correct thumbstick replacements...
I can't find anywhere that sells the replacement thumb sticks to replace. My son's left thumbstick cracked and broke and the switch pro thumbsticks you can get from ebay etc don't fit.
11 outras pessoas executaram este guia.
19 comentários
My controllers are drifting, What can i do after getting the joystick of to fix that.
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
I have just found them (I think, fingers crossed) on Aliexpress
oclose -
I get drift and I need help fixing that can someone please help me get rid of the drift
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there and i cant use it anymore i need to play my Right anolog stick ( from my switch ) to hold it and use my controllers left analog stick to move
BrunoS -
My controller is drifting how can I fix that
BrunoS -
Hi, Where can I buy replacement sticks, mine are trashed?
You can try looking up small hole controller thumbsticks on Aliexpress. Not the best but they’ll do. Might have to trim the edges a bit to fit through the front case.
Any idea where to get joysticks for these? I ordered switch pro controller joysticks and the hole underneath is too big for the rod.
I may have find what is the exact part that make up the joystick: https://www.sparkfun.com/products/16273 based on that, the replacement joystick should be this: https://www.sparkfun.com/products/17263
I will try to order some and post back if that works.
I ended up buying those but will only receive them in a month: https://www.aliexpress.com/item/10050031...
I received my replacement tumb stick from AliExpress and they 100% work! They are much cheaper feel than the original thumbstick but at least I have a working controller. You can get them here: https://www.aliexpress.com/item/10050031...
I ordered the same and I can confirm, they fit and work great!! They look better than on the photo of the store site.
I even put my thumbstick rubber on it and it fits perfectly as well.
So I have what should be a power a enhanced wireless pro controller, but the one I have doesn't use AA batteries, how do I remove the internal battery out of a model that doesn't use AA batteries
