Ir para o conteúdo principal
PowerA Enhanced Wireless Controller Directional Pad Replacement
O que você precisa
  1. PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, imagem 1 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, imagem 2 %32 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the rubber tweezers to grab the center of the directional pad and pull it out by pinching its center.
Conclusão
Ayjah Montgomery
Membro desde: 10/10/19
420 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 34
Ao todo: 1,290
