Ir para o conteúdo principal
Power on HTC Desire HD
  1. Power on HTC Desire HD, Turn on your Desire HD: passo 1, imagem 1 %32
    • Reach up to the top of the device.
    • Press and hold the power button for 3 seconds.
  2. Power on HTC Desire HD: passo 2, imagem 1 %32
    • Your device should now be on.
    • If it doesn't turn on:
    • Make sure you held the power button long enough.
    • Connect the charger (The battery may be flat)
    • Make sure a battery is present in the battery slot.
    • If all else fails, refer to instruction manual or contact HTC Customer support.
Conclusão
To turn the device off: 1. Unlock the Device 2. Hold the power button (3 secs) 3. Tap on the "Power Off" Button
20 outras pessoas executaram este guia.
NotTelling
Membro desde: 11/14/14
608 Reputação
Autoria de 1 guia
2 comentários
Comment changé l'écran tactile HTC désire hd
Amar Mokrani - Responder
ha....hahaha :) having a bad time and then this! gonna be a good night,
tyler mcney - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 2,780
