Ir para o conteúdo principal
Power Macintosh G3 Minitower Floppy Drive Bezel Replacement
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Gently pry up the tab on the left side of the floppy drive bezel.
    • Swing the bezel open.
    • Remove the bezel from the right edge of the floppy drive.
Conclusão
LeoI07
Membro desde: 06/10/21
1.573 Reputação
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 106
