Ir para o conteúdo principal
Power Macintosh G3 Blue and White Graphics Card Replacement
O que você precisa
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: passo 1, imagem 1 %32
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: passo 2, imagem 1 %32 Power Macintosh G3 Blue and White Graphics Card Replacement: passo 2, imagem 2 %32
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: passo 3, imagem 1 %32
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
Conclusão
[deleted]
Membro desde: 08/28/18
26.550 Reputação
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 33
Duração total: 1,609
