Ir para o conteúdo principal
Power Mac G5 Top Left Cooling Fan Unit Replacement
  1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: passo 1, imagem 1 %32
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 2, imagem 1 %32
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 3, imagem 1 %32 Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 3, imagem 2 %32
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 4, imagem 1 %32 Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 4, imagem 2 %32 Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 4, imagem 3 %32
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: passo 5, imagem 1 %32
    • Locate the top left cooling fan unit.
  6. Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 6, imagem 1 %32
    • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
  7. Power Mac G5 Top Left Cooling Fan Unit Replacement: passo 7, imagem 1 %32
    • After pulling out the fan unit, the area should look like this.
Conclusão
20 outras pessoas executaram este guia.
Salvador Aguilar
Membro desde: 01/21/10
2.550 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-8, Forte Winter 2010 Membro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membros
Autoria de 30 guias
1Comentário do guia
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 101
Ao todo: 19,818
