Ir para o conteúdo principal
Power Mac G5 CD-ROM Drive Replacement
  1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: passo 1, imagem 1 %32
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 CD-ROM Drive Replacement: passo 2, imagem 1 %32
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 CD-ROM Drive Replacement: passo 3, imagem 1 %32 Power Mac G5 CD-ROM Drive Replacement: passo 3, imagem 2 %32
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 CD-ROM Drive Replacement: passo 4, imagem 1 %32 Power Mac G5 CD-ROM Drive Replacement: passo 4, imagem 2 %32 Power Mac G5 CD-ROM Drive Replacement: passo 4, imagem 3 %32
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: passo 5, imagem 1 %32
    • Locate the CD-ROM Drive on the top left corner of desktop.
  6. Power Mac G5 CD-ROM Drive Replacement: passo 6, imagem 1 %32 Power Mac G5 CD-ROM Drive Replacement: passo 6, imagem 2 %32 Power Mac G5 CD-ROM Drive Replacement: passo 6, imagem 3 %32
    • Pull and rotate latches to the left.
  7. Power Mac G5 CD-ROM Drive Replacement: passo 7, imagem 1 %32
    • Wiggle and pull out the CD Drive.
  8. Power Mac G5 CD-ROM Drive Replacement: passo 8, imagem 1 %32 Power Mac G5 CD-ROM Drive Replacement: passo 8, imagem 2 %32
    • Detach the first cable from the CD-ROM drive.
    • Detach the second cable from the CD-ROM drive.
    • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
  9. Power Mac G5 CD-ROM Drive Replacement: passo 9, imagem 1 %32
    • After the CD-ROM drive is removed, the area should look like this.
Conclusão
44 outras pessoas executaram este guia.
Jessica Chaidez
Membro desde: 01/13/10
8.052 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-8, Forte Winter 2010 Membro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membros
Autoria de 30 guias
2Comentários do guia
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - Responder
Misleading title. I know how to unplug the drive, thank you very much.
I've replaced the original drive with a better one and the %#*@ tray is stuck because it's too high.
engineer2137 - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 92
Ao todo: 35,737
