Ir para o conteúdo principal
Power Mac G4 Quicksilver video adapter card replacement
O que você precisa
  1. Power Mac G4 Quicksilver video adapter card replacement, Opening the case: passo 1, imagem 1 %32
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver video adapter card replacement: passo 2, imagem 1 %32 Power Mac G4 Quicksilver video adapter card replacement: passo 2, imagem 2 %32
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver video adapter card replacement: passo 3, imagem 1 %32
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver video adapter card replacement, Video Adapter: passo 4, imagem 1 %32
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver video adapter card replacement: passo 5, imagem 1 %32
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver video adapter card replacement: passo 6, imagem 1 %32
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver video adapter card replacement: passo 7, imagem 1 %32 Power Mac G4 Quicksilver video adapter card replacement: passo 7, imagem 2 %32
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
Conclusão
7 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 14-41, Regan Winter 2010 Membro de Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 4,146
