Ir para o conteúdo principal
Power Mac G4 Quicksilver Video Adapter Replacement
O que você precisa
  1. Power Mac G4 Quicksilver Video Adapter Replacement, Opening the case: passo 1, imagem 1 %32
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Video Adapter Replacement: passo 2, imagem 1 %32 Power Mac G4 Quicksilver Video Adapter Replacement: passo 2, imagem 2 %32
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Video Adapter Replacement: passo 3, imagem 1 %32
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Video Adapter Replacement, Video Adapter: passo 4, imagem 1 %32
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver Video Adapter Replacement: passo 5, imagem 1 %32
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver Video Adapter Replacement: passo 6, imagem 1 %32
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver Video Adapter Replacement: passo 7, imagem 1 %32 Power Mac G4 Quicksilver Video Adapter Replacement: passo 7, imagem 2 %32
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Power Mac G4 Quicksilver Video Adapter Replacement, Video Adapter: passo 8, imagem 1 %32
    • Your card is now completely removed and ready to be replaced.
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 14-41, Regan Winter 2010 Membro de Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 7,136
