Introdução
Removing the power supply of the Power Mac G4.
O que você precisa
The handle to open your computer is located on top of the right side panel.
The optical drive is in the top left corner of the case.
Before sliding out the power supply make sure to disconnect the cable to the big fan by pressing in the small black tab on the back of the black connector!
Slide the power supply away from the back of the computer and pull it out carefully stringing the cables through the hole in the metal support.
24 outras pessoas executaram este guia.
5 comentários
I hate to say this, but that is not fixing the power supply but replacing the power supply with a new unit. i was hoping to fix it as mine blew and was hoping to revive it, but not luck on this end by the look of it. :(
Thanks for the clear instructions to replace the power supply. I got my part on eBay for $29 (other online stores are charging $100-200+ for it) to doctor up an old G4, and it works like a charm now.
Is it normal that after installing a replacement power supply for the PowerMac Quicksilver 733MHZ one of the fans is still running? Not sure which one, but once everything is shut down completely, I just pull the plug to avoid that fan from running for ever. Any feedback is appreciated. That unit still runs under OSX 10.4.11 and Classic.
