Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This is meant to be a private prereq guide.
Peças
Nenhum componente especificado.
  1. The hard drive is located in the back right corner of the case.
    • The hard drive is located in the back right corner of the case.
  2. Remove the flat ribbon cable by pulling with substantial force.
    • Remove the flat ribbon cable by pulling with substantial force.
  3. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Remove the screw holding the hard drive to the computer.
    • Remove the screw holding the hard drive to the computer.
  5. Pull the drive up and out of the computer.
    • Pull the drive up and out of the computer.
  6. Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
    • Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
Conclusão
10 outras pessoas concluíram este guia.
Ryan Bylard
Membro desde: 20-01-2010
1.280 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 14-41, Regan Winter 2010 Membro de Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Membros
10 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7,246
