Introdução
How to remove the processor from the logic board.
O que você precisa
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
Remove processor by pulling vertically upwards.
13 outras pessoas executaram este guia.
2 comentários
anyone still sell the replacement processor?
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
