Ir para o conteúdo principal
Power Mac G4 M5183 Processor Replacement
O que você precisa
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 1 %32 Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 2 %32
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: passo 2, imagem 1 %32 Power Mac G4 M5183 Processor Replacement, Heat Sink: passo 2, imagem 2 %32
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Processor Replacement: passo 3, imagem 1 %32
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Processor Replacement, Processor: passo 4, imagem 1 %32 Power Mac G4 M5183 Processor Replacement, Processor: passo 4, imagem 2 %32
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Linha de Chegada
13 outras pessoas executaram este guia.
Justin Petrilli
Membro desde: 01/21/10
3.114 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 13-24, Maness Winter 2010 Membro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
Membros da 4
Autoria de 25 guias
2 comentários
anyone still sell the replacement processor?
Joseph Cole - Responder
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Duração total: 12,077
