Ir para o conteúdo principal
Power Mac G4 M5183 Power Supply Replacement
O que você precisa
  1. Power Mac G4 M5183 Power Supply Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 1 %32 Power Mac G4 M5183 Power Supply Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 2 %32
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - Responder
  2. Power Mac G4 M5183 Power Supply Replacement, Main Fan: passo 2, imagem 1 %32 Power Mac G4 M5183 Power Supply Replacement, Main Fan: passo 2, imagem 2 %32
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Power Mac G4 M5183 Power Supply Replacement: passo 3, imagem 1 %32
    • Remove the power cable from the fan and detach bracing.
  4. Power Mac G4 M5183 Power Supply Replacement, DVD-ROM Drive: passo 4, imagem 1 %32 Power Mac G4 M5183 Power Supply Replacement, DVD-ROM Drive: passo 4, imagem 2 %32
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  5. Power Mac G4 M5183 Power Supply Replacement: passo 5, imagem 1 %32
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  6. Power Mac G4 M5183 Power Supply Replacement: passo 6, imagem 1 %32 Power Mac G4 M5183 Power Supply Replacement: passo 6, imagem 2 %32 Power Mac G4 M5183 Power Supply Replacement: passo 6, imagem 3 %32
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
    Just a Thank You note. What a great and absolutely clear guidance. Apart from a fairly current Windows/Linux set-up, I really like to work on my old Macintosh G4 running Mac OS 9.2.1 Your instructions just helped me to make that machine even more useful. And yes, I am using it for productive stuff. Thanks again and keep up the good work. Alex, Germany.
    Axel Stoecker - Responder
  7. Power Mac G4 M5183 Power Supply Replacement, Power Supply: passo 7, imagem 1 %32 Power Mac G4 M5183 Power Supply Replacement, Power Supply: passo 7, imagem 2 %32
    • Remove the 3 hex screws on the back of the case.
    • Remove the single screw on the side of the power supply casing with the Phillips #1 screwdriver.
  8. Power Mac G4 M5183 Power Supply Replacement: passo 8, imagem 1 %32 Power Mac G4 M5183 Power Supply Replacement: passo 8, imagem 2 %32
    • Remove power cable from the logic board.
    • Remove power cable from hard drive.
    • Pull the power supply out and towards yourself.
Linha de Chegada
18 outras pessoas executaram este guia.
Justin Petrilli
Membro desde: 01/21/10
3.114 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 13-24, Maness Winter 2010 Membro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
Membros da 4
Autoria de 25 guias
3 comentários
Had a nearby lightning strike, "scrammed" my Mac, but couldn't start it up afterwards. Google led me to the ifixit site ( where I should have gone first!) and your instructions got me going again. Granted, I had an identical, spare Macintosh so I was able to pull that power supply to replace the damaged one and not have to wait for a replacement, but your step-by-step made the swap fairly easy! Thank you! I am happy tonight!
Now to order the replacement.
Bill Pitts - Responder
Hello Bill, I was wondering what power supply did you order as a replacement. Getting an original would cost over $100 almost next to $200, so I want to make sure where else I can buy a good power supply. Thanks in advance.
Andrew R. -
ditto…. like Bill I had a faithful G4 i use to archive some old OS9 files that need specific software that never went to OS X and some very basic Apache web server stuff. Mostly sleeping it went pop one day, I had replaced it a few years previously after a pram issue with a clean SH unit which i just swopped drives over, so getting sleeping beauty down from attic, following instructions I removed the power pac and in 30 minus the dead mac was running again and archive is protected
ipodista - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 37
Duração total: 23,526
