Ir para o conteúdo principal
Power Mac G4 M5183 Main Fan Replacement
O que você precisa
  1. Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 1 %32 Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 2 %32
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Main Fan Replacement, Main Fan: passo 2, imagem 1 %32 Power Mac G4 M5183 Main Fan Replacement, Main Fan: passo 2, imagem 2 %32
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Power Mac G4 M5183 Main Fan Replacement: passo 3, imagem 1 %32
    • Remove the power cable from the fan and detach bracing.
  4. Power Mac G4 M5183 Main Fan Replacement, Main Fan: passo 4, imagem 1 %32
    • To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
Conclusão
3 outras pessoas executaram este guia.
Stephen Scruggs
Membro desde: 01/20/10
2.238 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-24, Maness Winter 2010 Membro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
Membros da 4
Autoria de 25 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 19
Últimos 30 dias: 32
Duração total: 7,772
