Ir para o conteúdo principal
Power Mac G4 M5183 Internal Battery Replacement
  1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 1 %32 Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: passo 1, imagem 2 %32
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: passo 2, imagem 1 %32 Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: passo 2, imagem 2 %32
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
Linha de Chegada
21 outras pessoas executaram este guia.
Justin Petrilli
Membro desde: 01/21/10
3.114 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 13-24, Maness Winter 2010 Membro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
Membros da 4
Autoria de 25 guias
4 comentários
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - Responder
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - Responder
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - Responder
The PMU reset button is inside the casing, on the same circuit board as the backup battery holder. See the second photo, it's a small silver square with a circular black button inset into its top and PMU Reset in tiny white lettering beside it. The photo shows it near to the battery holder but on my model the button is further away on the far corner of the circuit board. Look around for it. Insert the new battery then press the reset ONE time only.
Robert Nicholson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 28
Últimos 30 dias: 103
Duração total: 25,483
