Introdução
This guide will illustrate how to remove the heat sink from your PowerMac.
O que você precisa
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Quase terminado!
Linha de Chegada
6 outras pessoas executaram este guia.
