Ir para o conteúdo principal
Power Mac G4 Cube RAM Replacement
O que você precisa
  1. Power Mac G4 Cube RAM Replacement, Outer Case: passo 1, imagem 1 %32 Power Mac G4 Cube RAM Replacement, Outer Case: passo 1, imagem 2 %32 Power Mac G4 Cube RAM Replacement, Outer Case: passo 1, imagem 3 %32
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube RAM Replacement: passo 2, imagem 1 %32 Power Mac G4 Cube RAM Replacement: passo 2, imagem 2 %32
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube RAM Replacement: passo 3, imagem 1 %32
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube RAM Replacement: passo 4, imagem 1 %32
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
    If the Cube has an Airport card installed, it must be removed. This can be accomplished by disconnecting its antenna, and pulling gently on the clear plastic tab on its end. The bracket it is contained in must be unlatched from the frame and rotated out of the way to get to the two optical drive mounting screws beneath it.
    olearydq - Responder
    There is a ribbed cooling plate attached to the hard drive that must be removed before step 7.
    isitism - Responder
    There is no need to remove the four pillars. Skip step 4. In step 5, don't turn the Cube on it's side. The Airport slot swings out like a door, providing access to the IDE ribbon and power cables to complete step 6. Complete steps 6 and 7 while the cube is upright.
    Timothy Hood - Responder
    You really don’t need to remove all four pillars, or any of them depending on the repair you’re doing. They can be pulled out easily enough, just remove any that get in the way.
    N B - Responder
  5. Power Mac G4 Cube RAM Replacement, RAM: passo 5, imagem 1 %32 Power Mac G4 Cube RAM Replacement, RAM: passo 5, imagem 2 %32
    • Flip the two latches on the side of the RAM chip.
    • Remove the chip from the logic board and replace with new RAM.
Conclusão
11 outras pessoas executaram este guia.
Ryan Chun
Membro desde: 06/24/10
1.076 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 2-7, Johann Summer 2010 Membro de Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
Membros da 5
Autoria de 14 guias
Um comentário
Unless you have really fat fingers, you shouldn’t need to remove the metal plate and pillars. I’m able to replace the RAM without those steps.
Chris Sebes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 5,604
