Ir para o conteúdo principal
Power Mac G4 Cube Hard drive Replacement
O que você precisa
  1. Power Mac G4 Cube Hard drive Replacement, Outer Case: passo 1, imagem 1 %32 Power Mac G4 Cube Hard drive Replacement, Outer Case: passo 1, imagem 2 %32 Power Mac G4 Cube Hard drive Replacement, Outer Case: passo 1, imagem 3 %32
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Hard drive Replacement: passo 2, imagem 1 %32 Power Mac G4 Cube Hard drive Replacement: passo 2, imagem 2 %32
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Hard drive Replacement: passo 3, imagem 1 %32
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Hard drive Replacement: passo 4, imagem 1 %32
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Hard drive Replacement, Hard drive: passo 5, imagem 1 %32
    • Lift Airport slot.
  6. Power Mac G4 Cube Hard drive Replacement: passo 6, imagem 1 %32
    • Remove the power cord from the hard drive.
    • Remove the IDE cable from the hard drive.
    • Grip the sides of the hard drive and slowly pull outward.
  7. Power Mac G4 Cube Hard drive Replacement: passo 7, imagem 1 %32
    • Remove the three top screws of the hard drive use a T8 bit and remove the heat sink.
    • Carefully slide the hard drive to the open side (side without the IDE and power cables) to remove the drive.
    • Turn the drive over, remove the sled rail with a T10 driver for its two screws. Transfer the rail to the same side on the new drive.
    • Insert new hard drive.
Conclusão
21 outras pessoas executaram este guia.
Ryan Chun
Membro desde: 06/24/10
1.076 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 2-7, Johann Summer 2010 Membro de Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Membros
Autoria de 21 guias
1Comentário do guia
Strictly speaking, steps 2 through 4 aren’t necessary: you can just unscrew the heatsink from the hard drive, as in step 7, and carefully lift it out (I found that tilting it toward the optical drive and then pivoting it out worked).
bobtheflyingsquirrel - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 74
Ao todo: 19,211
