Ir para o conteúdo principal
Power Cord Removal
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Power Cord Removal, Safety precautions: passo 1, imagem 1 %32
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. Power Cord Removal, Remove the screw from the red knob: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
  3. Power Cord Removal, Remove the knob: passo 3, imagem 1 %32 Power Cord Removal, Remove the knob: passo 3, imagem 2 %32
    • Remove the red knob.
    • This component is keyed. During reassembly, ensure it is reinstalled in the correct orientation.
  4. Power Cord Removal, Remove the black cap: passo 4, imagem 1 %32
    • Remove the black plastic cap from the center of the switch assembly.
  5. Power Cord Removal: passo 5, imagem 1 %32
    • Use a Phillips screwdriver to remove the two screws securing the yellow switch guide to the switch assembly.
    • During reassembly, ensure this component is installed in the same orientation, with the circle in the 6 o'clock OFF position.
  6. Power Cord Removal: passo 6, imagem 1 %32 Power Cord Removal: passo 6, imagem 2 %32 Power Cord Removal: passo 6, imagem 3 %32
    • Remove the yellow switch guide from the switch assembly.
    • Remove the black plastic spacer from underneath the yellow switch guide.
  7. Power Cord Removal, Remove the upper switch housing: passo 7, imagem 1 %32
    • Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
    • These screws may not come out of their recesses in the housing once they are completely unthreaded. If some stay inside once loose, don't lose track of them.
  8. Power Cord Removal: passo 8, imagem 1 %32 Power Cord Removal: passo 8, imagem 2 %32 Power Cord Removal: passo 8, imagem 3 %32
    • Lift the upper half of the switch housing off of the lower half."
    • The rubber gasket may fall out of the upper housing during the removal process. Do not forget to reinstall the gasket upon reassembly.
  9. Power Cord Removal, Disconnect the power cord from the frame: passo 9, imagem 1 %32
    • Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
  10. Power Cord Removal, Remove the loom clamp: passo 10, imagem 1 %32 Power Cord Removal, Remove the loom clamp: passo 10, imagem 2 %32 Power Cord Removal, Remove the loom clamp: passo 10, imagem 3 %32
    • Remove the loom clamp from the power cable.
  11. Power Cord Removal, Remove the switch housing: passo 11, imagem 1 %32 Power Cord Removal, Remove the switch housing: passo 11, imagem 2 %32 Power Cord Removal, Remove the switch housing: passo 11, imagem 3 %32
    • Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
    • During reassembly, use a Phillips screwdriver in combination with the 11/32 inch socket wrench to tighten the bolts securing the switch to the bracket."
  12. Power Cord Removal: passo 12, imagem 1 %32 Power Cord Removal: passo 12, imagem 2 %32
    • Lift the switch assembly off of the switch bracket.
    • The switch housing bolts may fall out when you remove the housing.
  13. Power Cord Removal, Disconnect the green wires: passo 13, imagem 1 %32
    • Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
  14. Power Cord Removal: passo 14, imagem 1 %32 Power Cord Removal: passo 14, imagem 2 %32 Power Cord Removal: passo 14, imagem 3 %32
    • Separate the green ground wires from each other and move them away from the switch housing.
  15. Power Cord Removal, Disconnect the power cord from the switch: passo 15, imagem 1 %32
    • Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
    • During reassembly, ensure each wire is installed in its correct location on the switch.
  16. Power Cord Removal: passo 16, imagem 1 %32 Power Cord Removal: passo 16, imagem 2 %32 Power Cord Removal: passo 16, imagem 3 %32
    • Remove the black wire from the switch.
  17. Power Cord Removal: passo 17, imagem 1 %32 Power Cord Removal: passo 17, imagem 2 %32 Power Cord Removal: passo 17, imagem 3 %32
    • Remove the white wire from the switch.
  18. Power Cord Removal: passo 18, imagem 1 %32 Power Cord Removal: passo 18, imagem 2 %32 Power Cord Removal: passo 18, imagem 3 %32
    • Use a 1-1/16 inch wrench or an adjustable wrench to loosen the power cord's strain relief fitting from the switch housing.
    • Once the fitting is loose enough to turn by hand, twist the power cord and fitting counterclockwise until it is fully unthreaded from the switch housing.
  19. Power Cord Removal, Remove the power cord: passo 19, imagem 1 %32 Power Cord Removal, Remove the power cord: passo 19, imagem 2 %32 Power Cord Removal, Remove the power cord: passo 19, imagem 3 %32
    • Remove the power cord from the on/off switch.
Conclusão
Robert Boyd
Membro desde: 02/01/21
26.593 Reputação
Autoria de 94 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 43
