Introdução
If you need to remove the rear housing for the Porter-Cable PCE211, follow this guide. Removing the rear housing is necessary to access some internal parts of the impact wrench.
Prior to beginning this guide, be sure the impact wrench is off and unplugged from the power source.
Note: The screws holding the rear housing are fairly tight, so you will need some arm strength to remove them.
O que você precisa
Quase terminado!
Conclusão
