Ir para o conteúdo principal
Porter-Cable PCE211 Grip Replacement
O que você precisa
  1. Porter-Cable PCE211 Grip Replacement, Gearcase: passo 1, imagem 1 %32 Porter-Cable PCE211 Grip Replacement, Gearcase: passo 1, imagem 2 %32
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
  2. Porter-Cable PCE211 Grip Replacement: passo 2, imagem 1 %32 Porter-Cable PCE211 Grip Replacement: passo 2, imagem 2 %32 Porter-Cable PCE211 Grip Replacement: passo 2, imagem 3 %32
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
  3. Porter-Cable PCE211 Grip Replacement, Rear Housing: passo 3, imagem 1 %32 Porter-Cable PCE211 Grip Replacement, Rear Housing: passo 3, imagem 2 %32
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  4. Porter-Cable PCE211 Grip Replacement: passo 4, imagem 1 %32 Porter-Cable PCE211 Grip Replacement: passo 4, imagem 2 %32
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  5. Porter-Cable PCE211 Grip Replacement, Anvil: passo 5, imagem 1 %32 Porter-Cable PCE211 Grip Replacement, Anvil: passo 5, imagem 2 %32 Porter-Cable PCE211 Grip Replacement, Anvil: passo 5, imagem 3 %32
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
  6. Porter-Cable PCE211 Grip Replacement, Motor: passo 6, imagem 1 %32 Porter-Cable PCE211 Grip Replacement, Motor: passo 6, imagem 2 %32 Porter-Cable PCE211 Grip Replacement, Motor: passo 6, imagem 3 %32
    • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
    • Pull the motor out with your hands.
  7. Porter-Cable PCE211 Grip Replacement: passo 7, imagem 1 %32 Porter-Cable PCE211 Grip Replacement: passo 7, imagem 2 %32 Porter-Cable PCE211 Grip Replacement: passo 7, imagem 3 %32
    • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
  8. Porter-Cable PCE211 Grip Replacement, Grip: passo 8, imagem 1 %32 Porter-Cable PCE211 Grip Replacement, Grip: passo 8, imagem 2 %32
    • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
  9. Porter-Cable PCE211 Grip Replacement: passo 9, imagem 1 %32 Porter-Cable PCE211 Grip Replacement: passo 9, imagem 2 %32
    • Pull the grip from the body of the impact wrench.
Conclusão
Uma outra pessoa concluiu este guia.
Layla Berry
Membro desde: 09/19/22
678 Reputação
Autoria de 7 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 107
