Ir para o conteúdo principal
Porter-Cable PC60TAG Power Cord Replacement
O que você precisa
  1. Porter-Cable PC60TAG Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Cord Replacement: passo 2, imagem 1 %32
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Cord Replacement: passo 3, imagem 1 %32
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
  4. Porter-Cable PC60TAG Power Cord Replacement: passo 4, imagem 1 %32
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  5. Porter-Cable PC60TAG Power Cord Replacement: passo 5, imagem 1 %32
    • Careful remove each wire from the power cord from underneath the terminals.
Conclusão
Equipe
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Membro de UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 457
