Ir para o conteúdo principal
Porter-Cable 382 On/ Off Switch Replacement
O que você precisa
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: passo 1, imagem 1 %32 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: passo 1, imagem 2 %32
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: passo 2, imagem 1 %32 Porter-Cable 382 On/ Off Switch Replacement: passo 2, imagem 2 %32
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: passo 3, imagem 1 %32
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Conclusão
Nick O'Sadcia
Membro desde: 03/11/16
421 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 233
