Ir para o conteúdo principal
Porter-Cable 382 Dust Seal | Dust Break Replacement
O que você precisa
  1. Porter-Cable 382 Dust Seal | Dust Break Replacement, Sander Pad: passo 1, imagem 1 %32
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Dust Seal | Dust Break Replacement: passo 2, imagem 1 %32
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Dust Seal | Dust Break Replacement, Dust Seal/ Break: passo 3, imagem 1 %32
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Dust Seal | Dust Break Replacement: passo 4, imagem 1 %32 Porter-Cable 382 Dust Seal | Dust Break Replacement: passo 4, imagem 2 %32
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
Conclusão
jpfoxracing9
Membro desde: 03/11/16
189 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 548
