Introdução
The replacement process for this part is very simple. It will only take a few minutes, and you can continue with your day.
O que você precisa
Undo the black latch located on the base of the router by pulling upwards from underneath it.
Locate the 30 mm bolt and nut attaching the latch to the base.
Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
Quase terminado!
Conclusão
