Introdução
Before beginning this repair guide, be sure to unplug the charger from the computer and handle the battery with care. Avoid using sharp metal objects around the battery when ever possible. After finishing this guide you should notice a considerable battery life extension to your computer after being unplugged.
O que você precisa
Flip the laptop over with the screen facing down to reveal the bottom panel.
Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
Um comentário
can we still run it without battery? i mean using direct power supply and no battery install
