Ir para o conteúdo principal
Pop-Up Assembly Stopper Piece Replacement
O que você precisa
  1. Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: passo 1, imagem 1 %32 Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: passo 1, imagem 2 %32
    • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
    • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
  2. Pop-Up Assembly Stopper Piece Replacement: passo 2, imagem 1 %32
    • Disconnect the pivot rod from the center pop-up extension.
  3. Pop-Up Assembly Stopper Piece Replacement: passo 3, imagem 1 %32 Pop-Up Assembly Stopper Piece Replacement: passo 3, imagem 2 %32
    • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
  4. Pop-Up Assembly Stopper Piece Replacement: passo 4, imagem 1 %32 Pop-Up Assembly Stopper Piece Replacement: passo 4, imagem 2 %32 Pop-Up Assembly Stopper Piece Replacement: passo 4, imagem 3 %32
    • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
  5. Pop-Up Assembly Stopper Piece Replacement: passo 5, imagem 1 %32 Pop-Up Assembly Stopper Piece Replacement: passo 5, imagem 2 %32
    • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
  6. Pop-Up Assembly Stopper Piece Replacement: passo 6, imagem 1 %32 Pop-Up Assembly Stopper Piece Replacement: passo 6, imagem 2 %32
    • In the sink, the pop-up stopper will be loose.
    • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 22
Ao todo: 1,676
